I was looking for a reel and came across a good deal on an electric reel. Technically i dont need it electric since im starting up but entertain me here for a minute. What would i need to make it work? A battery? Some wiring? A charger for the battery?
It may be more work than what i need right now but just wondering what setup would i need to make it work. Thanks and stay safe out there.
I would definitely pickup that reel if it’s in good shape and works for what you’re needing it for. All you need to operate it is a 12v power supply. Just get a deep cycle battery. You’ll need the proper gauge wire to wire the reel to the battery and will need to charge the battery every now and then.
I e-mailed Hannay about the wire size for electric reels and he said to use 10 gauge. I checked a chart and because I am running it about 10’ - 12’ the chart says 8 gauge. Everything I see on the forums, FB and Youtube looks like everyone is running 4 and 6. Is there something I’m missing?
Oh, you’re welcome. And I can vouch for Blue Sea electrical components. I used a bunch of their stuff (breakers & fuses, bus bars, etc) building a camper van with solar panels, fridge, lights, fans, etc.
I used 10 gauge for all the wiring on my trailer. Lighting, reels, pump, schertz box. It allows plenty of power to go through everything with no problems
Although that’s probably fine I would use the proper gauge wire. If you go from a 10 gauge down to a 16 or something small for an led light you can create a lot of resistance and resistance creates heat.
