Has anyone tried this before? I feel like the person could have had their windows cleaned before they got the house washed… If it did work as showed I’m sure some of us would consider using it occasionally. Also not sure if there could be any negative effects to some types of siding/ oxidation. Just curious after seeing this post this morning.
Mr Clean does the same thing…but it’s by no means a “window cleaning” or would I advise them to have windows done before hand,
You can’t control TDS in water without filters or resin.
I know of some WC that add Rain-X to their wash water, seems like it would help with sheeting and reduce tap water spotting when pressure washing. Haven’t tried it personally though.
