I see lots of conflicting threads with different opinions on these two starter surface cleaners. Which would you pick for a first surface cleaner? I’m running 4 gpm 4200 max psi.
I was about to purchase the eagle wash ew1000, but something told me to ask here and see what you all thought about the BE WhirlAWay 16 inch model.
I can get the BE for about $200 less, but do you think I will regret that at some point? If so, why?
The Eagle Wash is excellent to pair with a 4200/4. I have that model running it with a 5.5gpm machine and it works great. A friend of mine has a 4200/4 that he runs a 20 inch BE whirl a way. His crapped out after about 2 years using it maybe twice a week. He replaced the cartridge for $150. It depends on how often you’ll use it. If it’s an everyday thing I’d go with the Eagle Wash. If it’s just to do a driveway here and there you’ll be fine with the BE
