Just add more SH until it starts to clean how you want it too
Bingo. Simple is best. No reason to over complicate it.
Hey Brad, TY. But, I don’t know how to do the Ratio Test per se.
Flow your gun in a bucket or trash can for 30s or a minute without the injector pulling, then pull from the injector for the same time and measure what you pulled versus what you flowed.
That is a topic that has been discussed many times on here. Search for bucket test or downstream ratio. You should find several posts discussing it. Was one a few weeks ago.
Keep stuff simple buddy. Most of the time with your set up: 1:1 or 2:1 water to sh ratio on the mix for ds. I would definitely add elemonator. Worth every penny. So in a 5 gal bucket anywhere from 2-5 oz of elemonator. Let it dwell and rinse. If after 10 minutes it’s still there it’s too weak possibly. Try 1:1 if it’s bad. It should get it. I did that with my 4 gpm machine.
