Has anyone plumbed a DS injector through a bulkhead at the bottom of your mix tank? How’d that work out for you? I’m pricing tanks from suppliers w/o bulkheads anticipating using draw straws and seeking to keep things as bulletproof as I can, but if I can clean this plumbing up by plumbing in from the bottom, I will. My concern is the bulkhead seal material failing.
If you’re going for “bulletproof”, I wouldn’t advise it. Mix tank bulkheads are prone to leaking whenever people plumb into them. The most common reply you’ll see on here is to buy a mix tank without a bulkhead if you have the option. Is there a price difference that you’re seeing? I got one with a bulkhead and capped it, but I check it every time I pull back into the shop
Sort of what I was thinking. Yeah I’m just going to source some without bulkheads. No reason to add to things to check/things that can fail.
