Today I have a dribble of water constantly coming out of the gun when off the trigger. This is obviously causing the pump to work more. I put a new whip line on this morning but I don’t see why that would cause this to happen. Any ideas?
Buy a new gun.
The seals are worn off.
How long have you had the gun?
Less than a year
No waranty then.
Need new one.
Make sure you rinse and clean all.your equipment after each work.
If it is a Suttner product it is probably a bad spring. Cleaning your equipment has zero impact on whether your gun is leaking.
