Downstreaming vs (soft washing)
I respect that.
I’m not going to hang you and your entitled to you opinion. I just don’t want another new person to read your comments later and think you are giving correct advice. We are self policing here.
I understand that completely. My experience and opinions will always differ from another. So can I ask how your experiences are with cleaning stucco downstreaming because I’ve tend to be intimidated before getting a xjet setup.
I typically don’t do stucco. If I do, 75% can be done ds’ing, the rest needs an xjet. My point for you was, it’s incorrect to say that you can’t clean stucco or brick by downstreaming
Here’s a video of brick that was downstreamed and rinsed with the same 0540 nozzle that I use.
Point taken.
I DS everything, and I’ve had good luck with stucco. True, I’ve had a few that I may have had to hit a couple of times, but who cares. Its kept me from having to buy and use an xjet which I have no desire to do. But as for brick, no trouble at all. So yes, I believe you can definitely clean brick and stucco by DS’ing. Now I will be honest and say that I am looking at a 12v system. But I’m looking at it for a roof system. But if I do get it I’m sure it would get used for other things than just roofs.
Yes I think I took a shot without aiming here lol. All downstream injectors are different and I use a 4gpm/4K machine and usually get good results. It’s just brick and stucco I find myself reapplying a lot. My eyes are on a system simply because I have a lot of inquires for roof washing. But I’m sure it’s one of those things where once you try it you would use it for much more. Funny thing is my local supplier is against those systems and swears I can clean any roof with an xjet lol. That is possible however not practical. I’m sure that is because he doesn’t sell any ā€œsoft wash/roof pump setupsā€.
Brad if you want to test mine out just give me a call it’s one of the best investments we’ve made. If you get a roof let me know. All I ask is for you to cover the cost of the SH used. I’d enjoy watching someone else work for a change. Lol
Will do Kenny! Thanks for the offer and I just might take ya up on it.
I downstream brick nearly every day and clean stucco ds also. Just depends. There is no ā€˜set in stone formula’ or canned answer. Reason you need the tools and/or experience to deal with different situations.
We did that HUGE brick home with a stucco front entrance and only time we touched the 12volt was for that black mold spot in the corner on that stucco. Probably didnt even need it. I think you was just showing how it worked lol (i believe that was the first time a met you)
Hey :slight_smile:
I’ve always downstreamed (4 years). It’s true, there are a few jobs where you need stronger chemical.
Personally, I don’t touch roofs, but a stronger mix to throw down on a particularly mouldy/black driveway would be very beneficial - both pre and post.
Even with a post treatment of neat SH, I regularly find myself with a sprayer doing touch-ups of bits that can’t be shifted with the surface cleaner or would need too much pressure with the gun/wand/lance.
I’d like to try a high draw injector, but I’ve struggled with finding someone who will ship one to me in Australia :frowning:
True indeed. Like i said I’m still new in my first year learning tricks of the trade. It may very well be the fact that most homes I get seemed to have never been cleaned since the civil war🤣
Like tools in a toolbox 1 tool won’t do it all…ya can’t turn a nut with a screwdriver…the same as you can’t clean concrete with dedicated pump systems…you can bleach it but that’s not cleaning concrete… yes DS’ing properly is soft washing…90% of what we clean is DS’ed…the other 10% we use 12v’s, air systems, or udor low psi systems…right tool for the right job that maximizes efficiency. Is what it’s all about… if you’ve been washing full time for 12 years you’re doing just fine, and better than most…all that matters is what’s in the bank…just saying.
Where did you come from lol. I was in canetuck yesterday replacing insulation. Merry Christmas friend
And to you too my Brother!
Not to take this thread off track (too far) but, you guys who are considering buying a 12 volt system, please feel free to call me and I’ll help you set up a DIY 12 volt system for way cheaper than a vendor-built one.
Also, you may want to consider building a small (1-2 gpm) ā€œChem cartā€ I use mine more often than my roof pump. It’s great for pre-treating driveways and spot treating stubborn stucco, dryvit, etc areas after downstreaming. I think I posted the link for it on here a year or two ago. If not, I’ll post it later on if you guys want it.
Good to see you @GuyB
I built my original 12v system piece by piece (before I sold it) for less than $400 with battery, pump, used tank, and hose. It paid for itself on one roof job. It’s handy to have for time when downstreaming just doesn’t cut it, but I can’t imagine buying a vendor Soft Wash setup for thousands of dollars. They might look pretty, but not as pretty as money staying in my pocket.
