Doing a big gas station and surface cleaning all pump pads tonight. What mixture do you guys use to downstream ebc? How much surfacant?
Depends on how dirty it is. Normal dirty I ds it at about 8oz per gal.
Get yourself an x-jet downstream chemical injector from water cannon, it is a must have and has a variety of different proportioning inserts So you can make your solution as strong or as weak as you see fit. It come with a proportioning chart and tells you the exact water to chemical ratio and each insert is color coded
At the rate Racer is calling for you can DS with no need for x jet
