I’m wondering if it matters what hose diameter I run from a 8gpm pressure washer to the gun?
For an 8 gpm I usually use a 8/16 hose
Thanks for answering so quickly! If you don’t mind me asking, what hoses have you found to work best for you? I’ve seen a lot of people recommend flexzilla, uberflex, ect, in your opinion what is the best bang for the buck?
I think it’s safe to say the majority of housewashers and concrete cleaners use the grey 1 wire non-marking hose, although I do go through 200’ a year.
If you only have 16/32” could that be used with similar results?
Only if you cut it in half…
Length wise, right?
of course!..it’s more economical too, cutting the 16/32 into two 8/16. The 16/32 hose seems to run the same price as the 8/16, so if I can get twice as much length out of it, I’ll cut it in half all day long…
Y’all been out in the heat too long.
