I picked the wrong words, it is not an expansion joint, it is one of the controlled breaking points they trowel in when they pour. It doesn’t have any expansion material in it. The slabs have shifted and separated about 3/4 of an inch. No idea when it happened, previous owners had it when it started.
It’s not so bad I feel it needs serious repair, however it is letting water run under the slab and that wont be good in freezing weather. The pea gravel and sand are just fill so the crack sealer can be a bit thinner.
Seems crack sealing and other minor repairs might fit with cleaning flat work.
I use Sikaflex for cracks, it takes a bit of practice to do a good neat job.
There are many different types of sika for different applications so make sure you get the right one , I recommend using the priming fluid before placing sealant as it promotes adhesion to both sides of crack.
