Can I use a quickconnect setup and use my pressure hose?
Should I just stick with a barb setup and use a smaller hose like the ones off pressuretek?
Problems with using a regular pressure washing hose?
Thanks for any help
Thanks for any help
You can use quick connects. You can use any hose you want as long as its the right size. If you had a big diaphragm pump I imagine a 1 inch pressure hose would be really expensive and heavy. Not to mention the shear overkill…
I have 1/2’’ NPT on my pump. I was thinking about using my regular hoses instead of buying a new hose that I wouldn’t be able to use with my pressure washer. Hence the quickconnect setup
It would go from 1/2’’ to 3/8’’ but the thought was keeping all my hoses the same and using different guns/attachments.
I prefer s lighter chemical hose. Always make the inlet side of the hose at,least one side bigger than the connection…
