FWIW - I asked my guy to spell out for me the process we used, so I could add it to our processes database…some of it is just quoting from the label:
Label instructions - “first cut at 4:1 to make product ready to use then follow the
dilution range listed below. Apply using pressure washer up or
downstream, or low pressure spray applicator.”
We used the xjet to apply the product as follows:
- Wet area
- Apply Cleansol (we used xjet)
- Allow to dwell for 5 minutes, keeping area from drying. (tip: Use the high pressure tip from a distance so that you’re just misting the area works the best to avoid rinsing off the chemical.)
- Apply a second coat Cleansol.
- Let it dwell for another 5 minutes, keeping the area wet.
- Rinse off area
