Custom CNC Machined Blend Manifold by PW Gadgets
PW Gadgets just dropped a new product that may peak your interest! The Blend Station is a real beauty! Budget price NOT a budget build. If you are on Facebook we are giving one away for free on July 4th. I’ll get the details and post them up here!
Nice……. Are these 6061?
Yes sir, careful attention was given to leave plenty of thickness where it needed it.
Excellent, You done a great job on them :ok_hand:
Thank you sir, that means a lot to me!
I thought about asking you about these today, regular blend manifold always has a new leak. And since the bulletproof injector from PW Gadgets works great…
What keeps this one from leaking where the plastic fittings thread in? How is it built different?
Thank you.
Great question, the only thing that would keep it from leaking at the plastic to metal connection is your ability to deeply seat your tapered pipe fitting, the use of a hard setting thread tape that won’t allow movement over time, threaded ports that are cut with a thread mill and NOT a tap followed by a check of the work with a Go/No-Go gauge so they stay within a very tight tolerance.
Then you eliminate every possible joint you can with selective plumbing. Bolt it down 8 times over and you’re set!
That thing would look sweet on my trailer. It would blend right in :sunglasses:
Thank you, but I know you have “toys” already!
There’s plenty of room for more amigo! Especially toys that shiny and fancy lol
Is that so??? Let me mirror polish one out for you then :wink:
@DisplacedTexan This is the look you should have got for your $1,250
Hell I would’ve been ecstatic just to have a flat mounting surface. You know…like yours does lol
We’ve all seen what SH will do to aluminum. Other than thinking it’s pretty, why would you possibly make the manifold out of aluminum, a material with always rated “D” or “D-” compatibility with sodium hypochlorite?
https://www.calpaclab.com/aluminum-chemical-compatibility-chart/
@OutsideCleaner Thank you for bringing this up Nate! I am aware of the chemical compatibility, on that note, I chose 6061 Aluminum because of its durability and cost effectiveness. This is a budget manifold after all. There are other material choices such as Titanium and Hastelloy however these come with a unbelievably expensive cost for material and machining. Then you have your Poly’s although they are chemical resistant they are ill suited when it comes to a material that is strong and durable. As this is a budget blend manifold we believe that Aluminum is the best choice. With diligent rinsing/neutralizing practices you will get plenty of longevity for your money. Because we designed these ourselves we left a hefty amount of wall thickness throughout but let us not forget we’re dealing with SH here and at this budget price nothing is going to be bullet proof. Choose to focus on a system with fewer leak points, quality valves and a design with a secure way of mounting. Because that is exactly how you get the most bang for your buck. At $350 this is the nicest well thought out Blend Station!!!
@OutsideCleaner Hey Nate :wave: just wanted to update you they all survived their first year. :wink:
My injector is still working fine too👍
I got another 100 in today. I’ll set one aside for you :grin:
I need one too!
Have you checked out www.pwgadgets.com?
