What works best to remove the stains the crepe mytrle trees leave on concrete? The fruit they produce falls and gets run over or decomposes leaving bad stains
SH and surfactant works fine.
I haven’t seen good results with that. What % mix?
Surface clean the area…downstream hw mix…within 10-15 minutes they are gone…any really stubborn areas hit with pump up sprayer with same mix
^^^ what he said
