Hi All,
I have a job coming up at the end of the month washing the shop floor for one of my fleet clients. Floor is concrete with oil/diesel/hydraulic fluid stains. What chemicals would you use to lift these stains?
I have zep purple degreaser, hot water and a surface cleaner. Should I spot treat first then wash with heat then post treat and rinse?
EBC Hands down, It’s pricey but it works.
I once did a 30 year old transmission service shop, 4 day’s later they where laying down an Epoxy coat… The oil was gone!
Hey Chesebro can you tell us more about that. It sounds very interesting. I searched but couldn’t find a post on it. Thank you!
Thanks, i kinda figured EBC… if yoi dont mind what was your process? Pre treat spots with ebc, surface clean done or did you post treat?
If you can’t get ebc, just straight zep purple or purple power from Wal-Mart will do amazing.
First spray it all down with straight degreaser, surface clean, then degreaser again, and pw again.
