What do you all use for composite decking?? I’v Been using SH mix and I’ve always had great results but I recently heard it could be damaging to the composite??
Everett Abrams is the guru. I will link his channel. I believe this has been discussed a few times on here. Tons of info here.
SH is fine on composite. The only thing to watch for is first generation Trex. It’s very porous so it needs more Chen’s and some light pressure but it can lighten in color tremendously.
Didn’t find any real answers from everett… anyone try corte clean?
SH is your best bet for cleaning composite. If it’s really bad I will brush it too. Don’t use pressure on composite.
