For Sale: New TurnKey Powerwashing Truck. $13,500 or best offer.
Selling a new complete powerwashing and roof cleaning truck mounted setup with truck (only used for ~3 hours). Comes with everything you need to start (or supplement) your pressure washing business. Setup for downstream injecting and X-Jet. All you will need is a ladder and you’re ready to go for roofs as well. Willing to deliver within a 10 hour drive from North Carolina. See below for itemized list:
Truck:
2007 Dodge Ram 1500, 8 ft bed. ~110,000 miles. Great shape. All items are securely bolted / fastened to the truck bed. See pics.
Equipment:
Pressure Washer: 5.5gpm / 2500 psi – Honda GX390 13HP, belt driven. General HP5535 Pump with electric start.
Roof Pump: 12V system (Delavan 5gpm 60psi). New Marine battery.
Hoses:
120ft garden hose (on reel). 250Ft high pressure hose (150ft on reel, 100ft separate. With quick connects). 150Ft 1/2” chemical hose (Pliovic braided orange hose, on reel).
Reels are all Hannay, graphite color. High pressure hose has high pressure reel. Chemical reel is chemical applicator hose reel.
Rest:
1 x 125 gal buffer tank
1 x 35 gal chemical tank
1 x Giant Gun assembly with 36” lance
1 x Fixed Injector
1 x X-Jet M5 kit
3 x Hose Reel stands so that the reels are on the sides of the truck
1 x Ladder Rack
1 x Whisper Pro Eagle Wash 20” surface cleaner
1 x M5D5 variable twist nozzle
1 x Gal jug of elemonator soap
1 x 5 Gal bucket with drawing system for X-Jet.
Whole truck setup is plumbed and ready to go. Separate water drain / hand cleaning / bucket cleaning drain pipe. Pump is plumbed back to the buffer tank so that when you aren’t pulling the trigger the water circulates back to prevent overheating and pump damage. Down stream injector is plumbed directly to chemical tank, just need to use chemical drawing tips (M5D5 twist nozzle included). Roof pump is plumbed directly to the chemical tank and buffer tank so you can choose either. Pics below.
