Hi just wanted to introduce myself my name is Shane. I’ve been a member and followed this forum for the last couple of years. There a lot of great info on here. My partner and I have decided to sell our pressure washing trailer and van. We have a turn key setup that is ready to go . The main washer is a pressure pro 8gpm 3500 hot water unit. Only 548hours on pressure washer. a 300 gallon buffer tank. We also have 2 Gould’s booster pumps model# 5gbs0714p4 with pro switches and are plumbed through a pro- portioner. Both pumps are plumbed together so if for any reason one fails you can switch to the other one or use the other one just for fresh water. Booster pumps run off a champion 5500 generator. We have a 100 gallon chemical tank and crates that hold 5 gallon buckets for additional soaps all plumbed to the pro-portioner. Trailer has 4 300’ summit hose reels 1 with 200’ garden hose 1 200’ high pressure hose and 2 with 200’ chemical hose.trailer also has a back up pressure washer it’s a Honda gx270 with a new at pump model # rrv4g40 with about 5 hours on pump. Lots of extras- hose/guns and extensions. Spare parts couplings/fittings.
Little big guy 24” surface cleaner and a mosmatic 12” surface cleaner. For windows we have a xero pure ro/di water purification system with a xero 40’ wfp and brush also a rhg booster pump to pump right from buffer tank through the xero pure to your pole. Our van is a 2005 ford e350 with 66,792 miles van has a brand new jasper transmission new tires and brakes . Also I should mention we completely rebuilt the trailer before we installed all the equipment 2 years ago. The trailer has new everything including 2 new 3500lb axles all new shackles, wiring, rims, tires and jack. Pulls great. Many spare parts not listed. We’re asking $33,500.00 for everything. If your interested please private message on here and I’ll give you my number so we can talk. Here are some pics of equipment and van.
Why are you selling all the equipment?
Dang…totally getting out of WC and PW.
my business partner and I have decided to go our separate ways.
Where are you located?
I’m in Martinsburg, West Virginia
I’ve got a post here somewhere that says if you think you want a business partner, give him $10k and let him kick you in the sack. It will be cheaper and l less painful than keeping him. Good luck. Your about $15k over in your asking price for what someone will pay.
I would say his equipment is worth with the van right around 21-23,000.
