Russ,
What is available in the vac with pump out line that would accept a surface cleaner later?
For simply removing water and relocating it to a tank or on property discharge:
Portable Waste Water Capture and Recovery
[http://www.hydrotek.us/teksheet/Hydro%20Loop%20-%20Hydro%20Vacuum/RPV30E1%20and%20RPV50E1.pdf"]Tek Sheet]([url)
For removing and recycling water for reuse:
Vacuum recovery system
Tek Sheet
And the Sirocco vacs:
Electric Vacuum
Thanks for the reply Russ.
I would like to learn more about the price and availability of a PEV 2/30 system with basic vacuberm setup.
The PEV2/30 includes:
2 - 3 stage vac motors mounted on a 30 gallon waste drum
Portability cart
Auto pump out
50’ vac hose
4’ VacuBerm
3 - 4’ sand snakes
silt filter
For $2499.00
Plus freight from San Diego, CA
I can have one to you in a week.
That is the one I want. I will call with Credit Card in a moment.
I intend to separate the motors so that I can run the vac on standard household circuit/generator. Is that available as a factory option?
Each vac motor has a separate on / off switch. Keep in mind that the vac cord and the pump out cord need separate circuits.
What are your thoughts on the Vac Boom for removing water Russ?
The VacuBoom I know little of. The Vacu Berm and the Sirocco recovery system is a very effective water mover.
Tim,
It was good talking the other day. I have one of the Scirroco’s you want. Are you going to be doing what we talked about?
I always knew that I would one day have the reclaim system(s) needed to take on other jobs. I put off buying every used reclaim system that I saw for sale at half price of new because it wasn’t time yet. Then I sold a job the other day that would be perfect for a big ole vacuum so I ordered one from Russ. I got the PEV 2/30.
Then today I went on a sales call that would be perfect for reclaim. We’ll see.
I always enjoy talking and learning from the old heads, and you’re one of my favorites :). I still have some stuff to master in our current gig before we branch out but I expect that we will. Thanks again for the time on the phone.
Tim,
Its always great talking to you. I always have a story to tell my wife after we get off the phone…lol. Let me know how you make out with the reclaim system. Any tricks you find don’t hesitate to share?..I always find it interesting how your creative side or mind works. You are the man!
