What can you do with a 3000 psi 5gpm HOT Water that you CANNOT do with a 3000 psi 5gpm COLD Water?
Gum, Grease, and keep your hands warm.
Melt your foot off!
Sent from my iPad using Tapatalk HD
Turn your surface cleaner into a fog machine on a cold day.
burn hose lines in the customers grass
Make much more $$$$ in the commercial sector.
So let me ask you this. If you have a hot water pressure washer is there any reason for you to have a cold water one as well?
Sure, for either a backup in case you need it or if you have helpers/employees cause two machines operating is almost always better then one alone.
One Word…“Productivity”. The more gpm you have, the faster the work speed. Think of gpm as horsepower, the more you have the faster you are. Less time means more money, more time means less money.
Now if you have a hot water skid and you don’t “Need” hot water…just cut the switch off…Shazzam…Cold water pressure washer…it’s almost like magic…Lol!
