Coil replacement
I have a Landa 5-3500 and have no flow thru the coil. I call a local Radiator shop to see if they could clean it out but they said it had to have a little flow to clean it out. so where is a good place to get a replacement coil?
I would think a Landa dealer, I don’t know if they are an interchangeable part. I used to use those 5/3500’s exclusively, had a coil blow on one that was luckily covered by warranty. I watched them take it out, it took 3 guys and a fork lift! They are heavy and tough to move around.
Yes was very Heavy. I picked it out of there by myself last night.
Now that the coil is out, try running water backwards through it. If you can get a trickle, you may be able to descale it.
If you end up needing one, call me.
Russ is the man.
Thanks for getting a coil for my landa.
It fit prefect
Thanks Russ
If ya dont mind me asking, whats one run ?
Sent from my SGH-T999 using Tapatalk 2
The coil was like $400 plus shipping
