Can anyone give me some pointers on removing a large heater coil (8 gpm)? Kind of looks like disconnect plumbing and use a lifting resource (tractor) to lift it up and out? I would love for someone to tell me the the diesel in the insulation will just dissipate, but I’m betting that the safest option is to replace the insulation.
Seriously, diesel soaked insulation is NO big deal! Run what you brung
Thanks for getting back. Yes, I talked to Landa tech., and he said what you said. Especially if it’s not even dripping from the bottom of the coil assembly.
Again, thanks.
