Hey everyone, this is my first post here. I’ve been lurking for a long time and finally have a topic that I can’t find any good information on.
I’ve got a 4gpm, 4400 PSI direct drive Dewalt machine from the wonderful HD. I use a 50 gallon buffer. I had a 20 inch Whisper Wash, but had to walk way too slow and I wasn’t happy with the lines, so I got a 16 inch Whirl-a-Way. Changed the 2502 tips for 25025.
For me, surface cleaning is inefficient at best, but I’m trying to stick with a trailer-less setup (I mostly do window and gutter cleaning work) and surface cleaning is a great add-on that I want to keep.
A few weeks ago, I was surface cleaning a HUGE driveway. 3 passes over every spot, walking what felt like 1 mph.
After rising with the ball valve, I hooked back up to the surface cleaner and it wobbled more than I’ve ever seen/felt. Instantly I knew it was a clogged tip. Before starting to take the tip off to replace or unclog, I wanted to see what the result would be with the clogged tip.
Holy cow. Incredibly fast. Had to go over every spot ONLY ONCE, and could walk at least 2-3x faster. Was taking off really tough-on marks that I wasn’t taking off before. It was a little loud, but that’s ok with me. If I went a little too fast, it would leave swirl marks, so I’d have to dial it back a hair. But still, walking 2-3x faster and never having to go over areas a second or third time is a HUGE difference than normal.
About halfway through the job, the nozzle unclogged itself. ■■■■. Instantly noticed the difference. Back to having to cover an area 3 times and walking slow. I kid you not - I was literally putting small rocks and pieces of sand in the plug for the surface cleaner trying to clog it again, ha! I couldn’t, so the job took forever yet again.
Yesterday, it happened again. Wonderful feeling. Fastest and cleanest surface cleaning job of my life, thankfully on the BIGGEST driveway of my life. But today, back to being unclogged and slow as ever.
So here’s my question. How can I simulate this clogged tip? I’ve got a 2 bar surface cleaner, so would having one 25025 nozzle and one plug do the same thing? Or maybe one 25025 nozzle and one nozzle with a different size orifice nozzle (2501)? I know this is unconventional, but hey. If it works, it works.
And if there is something that I am completely missing, I’m all ears! Thanks in advance.
