Has anyone cleaned trex deck?if so what was your process and chemical mix
Sent from my SM-G900P using Pressure Washing Resource mobile app
We clean all composite decks pretty much the same. Roof mix, scrub brush after a few minutes dwell, reapply and dwell if needed. Rinse, sometimes up close and personal. Clean each board from end to end with out stopping.
Awesome, thank you Tim.
Do you use your soft wash tips for the rinse?
yes, but at 10 gpm
Ok. I’m at 4gpm. Do you think it will still work, or should I do something else?
Try a 45 degree 10 tip and see if it will clean when you hold it high enough above the board to cover the board width.
iPhone - Tapatalk
I’ll do that. Thank you Tim!
Also it might look like it is not getting cleaned, and you will be tempted to keep going over it again and again. It will be nice and bright and clean as long as you follow Tim’s instructions. I did one when I got down here in Florida and it didn’t look like it was cleaned. When I finished the driveway in front and went back to check it, I was shocked at how nice it came out. The customer was too. And remember even wand work without stopping, until you learn how to feather in.
^^^^ Very helpful info. Thank you!
