My lines and hoses are all filled with red stains as well as my buffer tank. Will it be diluted enough in my water that it won’t make a difference or should I worry about it? I can get new lines and clean out my tank with a brush with oxalic and downstream oxalic to clean out my hoses if that would work. What’s your guys 2 cents
alot of washer folks used hose shoot out some rust colored water when first starting out for the day. definitely keep your tank clean tho. let water run thru hose a but before starting to clean too. it happens.
