New here, could a 4000 psi hose take on a 4400 psi washer or would have to adjust the unloader. Thanks.
All day long. A 4000 psi hose isn’t sold to the masses on the verge of bursting, extra 400 is nothing. Not sure it matters either way, can’t say Ive ever used 4000 psi on a job.
PSI is not adjusted by the unloader, you change out the nozzles to select PSI.
