I know some of you will say to change the pump… but the question here is another, I have this Axial Cam Pump, in the Chemical Injection usually only soap run… since I have to remove the algae that are stuck on the sidewalk and on the wall of a house I want to use Chlorine, in your opinion could the Chemical Injection be ruined? Could chlorine ruin the hose and the gun? any option?
Yes, yes, and yes. But, that pump is on a throw away unit anyways, so go for it.
Is this for your house? You’re not trying out something new to you on someone else’s house are you?
doing it on my house
