What are some cheap roof cleaning systems out there? I’ve seen some kits on some of the suppliers’ sites for like $500 but just wondering what y’all recommend.
Also, besides the pump/chem tank, what else is absolutely necessary when getting into roof cleaning? A ladder stability bar? Ladder clip? etc
My first setup was:
55 gallon garbage can
$200 110 volt pump
Wand and nozzles from pressuretek $50.00
3 50 foot 5/8" garden hoses rubber Goodyear hoses
I second Tim. I’ve used other hose trying to pinch pennies when I first started roofs. First job, the hose ruptured pouring SH all over the yard. I packed up everything. Diluted the yard with garden hoses for 1 hour straight. I went home and ordered the 1/2 yellow kuri online right away and went back to the job with it. 100% confidence and performance with that kuri!
LA Pressure Washing LLC
“Taking Pride In What We Do For You”
I’m wondering how you made the garbage can function as a chem tank?
Easy you pour in chemo that you need for the job, drop in the suction hose from the pump and go to town… I mounted my pump on a piece of wood that straddled the top of the 55 gallon can, when the job was done I simply pored the remainder into storage cans, and rinsed it all out… When I first started doing roofs I did 3 my first year… It’s not that popular of a thing up by me and it requires quite a bit of selling… Most people around here have no idea… So I couldn’t justify spending a lot of money on something that I barely used… Now i do more roofs per year but still not enough to dedicate a whole trailer or truck to it so I have my setup - 55 gallon chem tank, 110 volt pump and Hannah hose reel with 3/4" - 5/8" rubber garden hose on it, mounted on moving dollies. When I need it we push it into our box truck, when we are done we clean it out and push it back into the shop…
While I have never had an issue with my Goodyear rubber hoses, I am aware that they are not exactly designed for the corrosiveness of roof cleaning… I will be replacing my hoses this year with the kuritec hoses…
