Has anyone ever used this brand? Does it work good?
I have. As long as it’s relatively fresh, it’ll do the job just fine.
Check the date code on the side, if it’s more than 3 months old it will take a lot longer to clean.
I have used in a pinch when I didn’t order my drum ahead of time. Does okay but seems a lot weaker then the 55 gallon drum I get on a regular basis. The drum is a lot hotter and preferred for me….
