Please help with cleaning solution mix recommendation and price !
Roof is about 3000 sq/ft
You might start with a lawn mower
Question, can’t tell from the photo but what’s the pitch? Accessibility and pitch are a big factor in how we price cedar shingles.
It’s not walkable can spray it from the gutter all the way to the top
I’m not an authority on Cedar Shake but I’ve done a few. If you can rent a lift or figure out someway to safely walk it, I’m of the opinion you will get the best result with a heavy coat of sodium percarb and a power rinse (at 500-800psi). You can brighten with oxalic/citric blend if you want. Otherwise two or three coats with 2.5% SH, and very little soap (about 1/4 what you normally do for an asphalt roof). LOTS of dwell time, and you might be able to rinse of the lichen with a garden hose. Sometimes algae is more stubborn. You want to finish of with at a minimum PM for Bleach or Bleach Wash to neutralize the SH from breaking down the wood, even better would be to oil it as a final step. I’d guess $.75/ft2 to soft wash, or $1.25/ft2 to power rinse, plus oil if they want it.
Great info!! Many thanks for the help
