We have (6) interior car washes that we maintain for many years now. Wondering if anybody has any experience with a good product that will remove the grime and soot from the interior walls? We are using an acid now, but the results do not make me that happy. They are cleaning it well but I would like it to be better.
I did a test spot on a self service car wash with subway tile and white panels. I wanted to bid on it and was trying to see what it would take to clean it. I tried several products but nothing worked. I talked with the guy that was refilling the soaps and wax at the car wash, and he gave me the name of a product that worked. It was called Klean-Wall. I applied it with a pump sprayer at 4:1 and rinsed it before it dried using cold water. I purchased it at Premier Car Wash Systems in Macon,Ga.
866-405-5616
Kleen wall is sulfuric & phosphoric acid blend w/#2 surfactant package if memory serves. Plastic fiberglass panels lose their luster after repeated 20+ times acid cleanings. Care needs to be taken to eliminate acid going into pit or reclaim loop, it will damage vehicle paint if water is reused.
