A costumer wants me to remove these tire tracks, will my surface cleaner work with cold water?
That’s asphalt. Those tire marks likely wouldn’t come up with hot water. Instead of actual tire marks it might just be tar or oil brought to the surface from the tire on a hot day. You have to be careful with pressure on asphalt. It’s nothing like concrete. He should just seal coat it to get rid of it.
racer mentioned a guy in georgia who sells products for asphalt cleaning. Give him a jingle. dragon juice I think it’s called.
Good luck. If the guy that did the burnout on the asphalt put any amount of sack into it, those marks will be a permanent part of the scenery. Asphalt melts.
