I have a small hose to do but a steep roof. If you are trying to apply a 50/50 mix on the roof can you downstream it with a regular powerwash or do they not have downstreamer that will do 50/50. Also new to cling on . Bought the sample package what ratio do you use per gallon? thanks
It will work but you need to add a squirt of dawn detergent and 1 cup of arm and hammer detergent to your mix. Apply, wait 15 minutes, rinse with yellow tip.
All I can say is don’t schedule any work until you know how a downstream injector works, it would be a little cheeky to charge a customer to practise on there home.
Cling-On is a proprietary blend of surfactants and dispersing agents that will not only thicken your mix it will also disperse your mix more evenly across the surface. Cling-on is also designed to rinse as well as it sticks. Just add 1 ounce of Cling-On per mix gallon of solution.
@bleachblaster that’s directly from the website. Gotta search a little.
In new to this, but from what I’ve read on this forum, downstreaming is almost never used for roof cleaning, because roofs require a much hotter mix than siding. It seems like people are using about 5% SH on roofs (someone please correct me if that is incorrect). Downstream injectors pull a ratio of somewhere in the neighborhood of 10:1, the hottest mix being around 8:1. With 12.4% SH and a 10:1 dilution you’re only getting about 1.2% SH on the roof. Too low for a roof, but fairly hot for siding (assuming people put roughly 0.8% SH on siding, again please correct me if I’m off on that).
If you have an XJet siphoning 12.5%, and your pressure washer is no more than 4 GPM, you might be able to get the mix hot enough for a roof. See this video about that and compare with what others say: M5 X-Jet: Roof Cleaning - YouTube
