Can’t find metal bands for 35 gallon tanks!
I have two used 35 gallon horizontal leg tans and neither the TSC or Rural King in my area carry the C-shaped metal bands to bolt them down to a trailer…where can I find them at??
These are the ones I used. Built well
https://www.ntotank.com/band-for-norwesco-35gallon-horizontal-leg-tank-x6434935
Thank you! I found some that were $20 so this is even better!
3/16 x 1" flat stock with ends bent 90 degrees
I make all my tank straps out of 1/8x4” aluminum. Local metal supplier sells them 10’ for $20 . No rust no special tools and only takes about 5 minutes to make.
Aluminum works great
If rural king dont have them then good luck. They have EVERYTHING.
I get mine from boydsequipment.com I think that’s the name,there some where in Texas
