that’s all. Just wondering.
Yeah it’s non detergent you’ll be fine
Don’t put cooking oil in your pump. Get the correct type of pump oil, it’s cheap and meant to be in there.
I know of a guy on my town who converts used cooking oil into diesel, it’s quite the process but can be done. Obviously I wouldn’t pour straight cooking oil into your pressure washers unless your auditioning for mythibusters
Yes, and you can cook with pump oil. Neither will give you the best results
You all just got the PW equivalent of Rick Rolled.
Yeah you can do whatever you want.
I guess olive oil is more efficient than vegetable oil.
avacado oil makes it run better in the winter
Whatever happened to Awesome wash?!
