Can i mix sh with degreasr
Im doing my first restaurant patio and im not sure if i can mix sh with degreaser or just use degreaser. The patio has mainly grease stains.
Thanks, makes sense
You can, but no need unless there’s organic stains. Just use the degreaser. Ignore the advice up above. The ph in both is almost identical. Learn some basic chemistry if you’re going to be in this business.
I was scratching my head on that one too, ‘bleach’ often has sodium hydroxide in it as a ‘booster’:expressionless_face:
So whats a good degreaser that you guys recommend
