Bypassing a hose reel question
So going to bypass my hose reel for my softwash system. I am using the flexzilla air hose and wondering if there are some good quick connect fittings that I could have put on that would stand up to the chemical.
Most poly fittings are around 150psi, so you should be okay but double check. I’d go with Banjo for brand.
Yep. I’d just recommend keeping spare gaskets on hand and check for leaks frequently. The bleach will break down the rubber over time.
Got them on order now lol.
