I’m planning on buying a new Pressure and soft wash skid for the first time. I’m getting mixed messages between a 12v soft wash system and gas powered system…what do you all recommend?
Thanks in advanced.
Thanks in advanced.
Get a gas powered pressure washer, belt drive and use a downstream injector for washing houses.
All the 12v does is let’s you put more than 1% strength on stubborn surfaces.
What are you using it for and what is your main service offer? Definitely would recommend and 8gpm pressure washer. We use 7gpm 12v for roof cleaning and thats good enough for us. But I believe an air system to be the best if you’re using it a ton. I’ve not heard great thing about the gas softwash pump but I’ve never used one.
Where I live most everyone has a concrete driveway or patio. Get a Whisper Wash surface cleaner matched to your machine. Get a 5.5 GPM power washer, 8 GPM is better with electric start.
My plan is to go after mostly residential jobs…concrete, house washing, and roofs. There are a lot of brick homes in my area as well as vinyl siding.
