Burner won’t fire
Hey all new here looking for any ideas. Burner is driving me nuts. I’ve gone through everything in attempts to get this thing to work.
Here’s where we are at.
New pressure switch
New fuel solioid
New fuel solenoid wiring and clip
Check, rechecked, and rechecked wiring diagram 500 times.
When I hit the switch fan turns on igniters are sparking fuel pump is pumping. Will not get fuel from the solenoid to the injector. I’ve put a new solenoid on and two spare/older ones to check with no luck.
I have no idea why we’re not getting fuel past the solenoid. Everything’s hooked up correctly.
Anyway an input would be appreciated.
Thanks for the replies.
I just tried the two mentioned methods. Fuel pump is doing good I got 120 psi currently and cranked it up to to 150 just to check. Back down to 120 again.
Hot wired the solenoid no change.
Cleaned the ports no change.
Mixed and matched all parts I had laying around to see if I could get something to work no luck. Might just go ahead and buy a whole new solenoid and go from there.
Did you try bypassing the Thermostat? Had that happen before.
Brand new T stat just installed also just grabbed a whole new fuel soliniod assembly and still nothing.
About to pull my hair out :joy:.
What’s the battery reading?
