We have a chance to bid on heavy equipment washing for a large excavating company. We’d clean everything in their gravel yard. Basically, what’s there when we come; stuff coming in and out from jobs all the time.
Pricing for heavy equipment like this? What’s an average price for a large bulldozer, front end loader, or track hoe? I’ve found info on trucks and trailers, but don’t know where to start on this type of work? Help!
When you do the @ and then their screen name, it sends them a message that they have been mentioned.
I did @Trey Winslow but it did not work because his handle here is TreyWinslow - all one word.
Let me try again. [MENTION=7146]TreyWinslow[/MENTION]
I mentioned Trey because he recently posted pictures of cleaning some rock drills so perhaps he could help with your question.
[MENTION=1670]Mulchtank[/MENTION] Did you get the notification of mention?
I have 2 accounts that are either on a construction site or at a yard with no access to water. If that is the case with you, you will need a large enough tank to tote the water around with you.
If you’re doing around $100/hr for contract fleet work you’re doing pretty well. We do a set of dump trucks and 12 rock drills that are done periodically. The trucks are done every 1-2 weeks and the drills are done about every month.
Charge more for the first initial cleaning of the equipment. Then if you get on a schedule with them you can give them a discount for having them done regularly.
