Bingo, but make sure you run the channel the length of the trailer. You may want to add or move shelves later, but either way it helps distribute the load.
Youâre killing me smalls. How many times do we tell people to get real chems and stay out of the big box stores and here you go asking about Lowes lol. Get Olympic maxxim
You will need to thru-bolt the unistrut from the outside. Could probably use 1/2â stainless carriage bolts. Depending on how the trailer is built might need a large fender washer on the outside of the trailer. Make a pattern or measure evenly from a straight line on the trailer so that the bolts look even as they go along and the shelf is straight on the inside. Do not use a level because the trailer might not be level. You can get brackets and cross mount unistrut at the exact distance of the hose reels so itâs all metal no wood.
Or if you donât want bolts going thru the trailer, just weld bolts to the frame from the inside. Have someone hold a bag of ice on the outside to keep the paint from bubbling or peeling
Just finished tonight, need to let it dry and clean up the floor a bit. Sherwin Williams exterior latex, was considering epoxy but was informed it doesnât hold up well to heat for extended periods.
I couldnât find one anywhere this past February. I had to use a 55 gallon drum. The drum sucks because I can get my hand inside to tighten the fittings I used. Had my 7 year old help me.
Iâm seriously looking at getting a couple vertical tanks, I did the math and two can be placed on either side and still allow for a âwalkwayâ between them for access.
I have 25 for SH. Not near enough. Want to go to 40 or 50.
I donât know how you clean concrete with an 8gpm on a 55 tank. There mus be insane water flow in your parts. I wouldnât even consider going with one less than 125.
