so what do i go buy ??
I’d get a 7gpm udor or Landa pump. I don’t know if you’re gear driven or belt driven, what size your engine side sheeve is etc. Go to you local vendor or call one of the online vendors and tell them what you have.
I am buying a new PREDATOR
15.8 HP (459cc) Max
any pump suggestion’s
Pump suggestions are literally in the post above your last post
sorry about that I am aware I was seeing what everyone think is good from user experience.
How would these modifications affect reach at height?
I need to get some information on running a bypass to my buffer tank I am looking in to getting a new unloader valve because the on that come with my pump I am not sure if it can be done with that one on the pump
Sorry don’t have photos on my phone will upload pictures of my setup soon as I get home
10HP Kohler commander with a Canpump Pressure Washer Triplex Pump, 3000 psi at 4.0 gpm, 1-inch Shaft
I think it’s a 150 gallon IBC tank
No.
thanks for the quick response and info been trying to get info for day and i would like to get a external order today
I have just removed my unloader valve i have just received this video on how to use the stock unloader with a bypass line
https://www.youtube.com/watch?v=JX9BDFLEHGY
do you guys think i should do this or just wait on a new unloader?
and i will be using a external General Pump 3-5 Gpm Chemical Injector
I say go for it. And report back how it works. I know a lot of guys that start off with cheap pumps with a similar “internal” bypass that would love to use this trick to bypass to their buffer tanks.
Ok I will give it a shot if it doesn’t work out I ordered a unloader valve all ready
Ya I had to get what I could for right now my season has started and I am having issues with my old2.3 GPM machine so I had to stop my 13HP Predator build but I am on the lookout for a new surface cleaner to use with me 4Gpm setup or can I change the tips on the one I have for my old 2.3 GPM?
Which surface cleaner do you have?
Sorry took me a min to reply been having some family issues and I had to get on the road for work
