I have a B&S with relatively low hours, it recently started chocking it self LOL
The choke will go on while working, Is there an adjustment or a spring that activates it? The machine has a manual throttle lever, anyone ever have this issue?
Vtwin?
If its like this motor, the choke limkage is under tension. See about 1min mark.
Yes V Twin
Thank you for the video link, I think my engines newer than that… It’s an early 2017
Can you snap a picture of how the choke operates on the Vanguard? Might be able to give you options after looking at it.
Mine did the same thing. There is a small screw where the choke is. Loosen the screw and take off the “squeeze bracket” that guide’s the choke. Clamp it down to increase the tension so it will stop turning off while you wash.
