Any of you guys knowxwhat to use to remove brake fluid from new concrete driveway?
Try a good degreaser and let it soak in for awhile then hit it with heat if you can.
I am a big fan of using simple green.Let it sit a while and then power it off .
Job done.Once or twice I have used it and it didn’t clean it completely … but with a second time cleaned it right off
Titan Oil Flo
