So these are probably dumb questions, but I have been researching everywhere (I swear) and can’t find the answers. So, Box Truck Floor Questions:
- Is it necessary/wise to paint an aluminum floor?
I mean, aluminum doesn’t rust right? And it holds up decent to corrosion right? So do I need to paint it? (I talked with one guy around me and he said no, but drill holes in the 4 corners so liquid drains out. That doesn’t sound right either to me.) - How do I secure my equipment (power washer, reels, buffer tank, etc.) to the floor?
I have inverted T aluminum flooring - see, at least I found out what the flooring is called in my hours of research. Do I drill through and bolt everything? Is the floor thick enough (between the “T’s) for self tapping screws to hold? Do I get it all welded to the floor?
Please help guys. Box truck guys, what have you done? What worked? What would you do differently now? Non box truck guys, what have you heard done? What have you seen done? What is your best guess? Any and all insight greatly appreciated.
