Hi. Wondering if anyone can recommend a company/person that sells/installs a 1.5 hp booster pump complete set up? Thank youfor any help!
Arkansas Softwash sells different setups.
Thank you. I will check them out
Only ones I’ve heard of being used are 3/4. And 1hp booster, if there is a 1.5 I’d love to see it in action
Does anyone have experience with those leader booster pumps?
Boosters go up in power as high as you like, the issue is powering them. Above 1hp you usually need 220v. Whip out the Google and you’ll see a ton from goulds and sta-rite.
