I also have their pro switch as well. This allows the pump to turn off when the trigger is not pulled.
I believe the pump is 5.5 gpm and at about 150 psi.
I can get 50 to 60 ft out of the pump.
As far as hooking it up you need a 3 way ball valve on the inlet side. One side for a water feed/ prime ( these are not self priming pumps). The other side I have it going to the proportioner.
The out side goes directly to a titan hose reel or you can hook it to a garden hose as well.
The pumps in/out are 1 inch female so you have to reduce them down 3/4.
Once I have all the components together I will snap some pictures. right now all equipment is tore down so we can rebuild it for the up coming season.
As for how long the pumps last? If you rebuild them every year then they should last for yrs as long and the motor stays running. My last pump motor lasted 2 plus yrs. Would have been more but one of my balls valves sprung a leak and it took my guy 2 days to tell me. It was an sh line.
No problem. As soon as I have it all built back up I will Post some pictures of the set up so people can visually see and get a better Idea of what I posted.
Yes we carry our own generator but we plug into the customers house when we can ( we get permission first). We we plus into a customers house it is very nice because there is no gas motors running. Its nice to hear yourself think sometimes ( not all the time) but it cuts down on the yelling back and forth for communication between the roof and ground guy.
You can use a honda eu2000 or a 3000/4000 watt generator for the 3/4 hp.
As far as the 1 hp I like the extra distance and you get a little more pressure but you need a bigger generator to run them so to me it wasnt worth the extra cost.
