Is my pump bad? Oil change to motor & pump, fresh gas, ignition coil, spark plug, adequate water pressure… Not sure what to do. Thank you.
I also rebuilt the carb and that didn’t fix the issue
I don’t see a video in the link. Is you unloader cycling?
Fixed the video link, gonna check unloader now.
Unloader valve seemed to fine no corrosion or grit. The washer hadn’t been ran in quite some time, initially it ran good no issues but after maybe 5minutes of use it started to bog
Is it cycling back and forth when you pull the trigger. Youtube is only way to post videos here that i can figure out
unloader is not cycling
I took apart the brass part on the pump and cleaned everything real good and applied new oil it seemed to do some good, now it doesn’t completely die but still bogs down. I can take a more detailed video of what I have done if that would help you guys troubleshoot
I’d be curious to see if unloader is cycling. To be honest, it’s not worth investing money to fix it so don’t spend to much effort on it
Run it without the gun.
See if it does the same
