Has anyone ever used any Enviro-safe chems on boat houses/docks with success? If so, what did you use?
I am looking at a job, that has a ton of cobwebs and other dirt/grime, no algae, on the inside of the boat house. The only other thing I could think of doing was using my extension pole and just brush them off before washing off.
When I was looking into jobs similar to this I found the EPA will slap your pee pee because of the clean water act. Even if you use literally just water, if it’s going into a stream, river, oceans etc it’s a big no no.
My research led me to not go anywhere near any job that was near water with potential runoff into those streams because fines are no joke.
@HSS I have had the opportunity to wash a boat house and a number of piers. I began by contacting my state department of natural resources. I was able to make phone contact with someone, explained what and how I was washing and after about 10 days received an email back stating that based on the soap and my percentage of SH, was given permission to proceed. I keep a copy of that email in my work trailer should someone question me. That is where I would start. The worst they can say to you is no.
That is very helpful, thanks! I don’t see how a handful of docks at a very low percentage would “ruin” a couple hundred acre body of water. Especially when they have to treat the same body of water almost monthly from the local farm runoff causing massive algae and hydrilla blooms.
I used to work with a few environmental consultants, they always said “The best solution for pollution is dilution”. Similar concept. I’ll be sending some emails in the morning.
@HSS Like @Dallsheep inferred, the headache and potential fines could be significant. At least an email from someone in the know giving you their blessing gives you something to fall back on. I hope it works out for you. I would like to buy a cheap pontoon, throw a small pressure washer on it and go from pier to pier around some of our lakes. I would be the $99 pier cleaner. Can’t think of a better way to spend the summer.
I was picturing something similar as well! If I can start to market boat houses/docks as well as boat hull and pontoon cleaning in the fall when they pull them out of the water. I don’t think I would have much of reason to venture elsewhere, especially since it already accounts for at least 50% of my schedule.
