Bleach mix ratio
Troll duty???
Asking about Bleach ratios… Do you even pressure wash, Brah?
*Trolling Duty… every community has a troll but why should the good people of PWRA settle for a low level amateur. I’m a professional and have staged a (currently) bloodless coup to usurp @thinktoomuch from his role.
Friends, Romans, PWRA-ans, as your new professional troll I promise to heartlessly dangle tempting, yet terrible advice before you.
I will mercilessly attack anyone who is more skilled than I (um… yeah so that’s all of you) and childishly call you noobs when I’m called out.
I will be a heart less troll but I know there is only enough trollburger in the forum for one troll. I will be that trolll. I will be YOUR troll. I will be the people’s troll. All other trolls will fall before me and leave or die of starvation when I consume all the troll burger.
Accept me into your hearts PWRA, and I will gently mock you sometimes but will protect you from other trolls.
As a community minded troll I have announce my arrival as Troll-in-Chief so you can read my posts with healthy scepticism. Once my reign is on solid ground I may consider allowing a democratic vote for the next troll
There’s something wrong with you.
(But you’re very likeable!!)
Houses don’t make you enough money not to many ppl want there house washed
Hashtag TROLL FAIL
Dammit. I’ll try to up my game a bit with some quality trolling
Pressure washers damage houses
Bleach kills dolphins
Hand washing a house with a rag dipped in organic kerosene is the only way to clean.
Only babies and weak people put a pressure washer in a trailer. Real man carry their machine under one arm and 40’ ladder under the other
I use to run 10% sh straight with a 4gpm machine and it worked great. I would not dilute the 8.5% sh. I use to pay 2.90 a gallon so not sure why it’s higher where you are. Even my 12.5% I only pay 2.50.
Good luck and the best way is to try several mixtures that’s right for you.
I bet it did…!!
Where do you get your 12.5% from? Online or local?
Pretty sure most are getting it local. Check around with local pool suppliers and should be able to find an outlet for it.
Thank you!
I found 12.5% at Menards in the pool supplies I think $3 a gallon
Getting 110 gallons delivered to my shop tomorrow for $2.80 gallon. It’s listed at 12.5 but the vendor says the first week it’s more like 14%
They pump it off the truck into my storage tanks.
